I picked up my '09 Speedmaster on Wednesday. 350 miles later - as I'm shifting into 2nd - the shift linkage fell off! Needless to say, I was more than a little disappointed.
Once I figured out what had happened, I screwed the linkage back together, and it held until I got home.
I was surprised that there wasn't even a drop of Loctite on either end of the rod. Is this normal? Can't Triumph afford a drop of Loctite, or at least a star washer?
This incident aside, I really like my bike.
I've had the same problem with my 08 Thruxton , it has come loose a few times . It is in the process of being replaced under warranty. i would do the same as you may find ( as was the case with mine) that the thread had been stripped from the linkage and so the problem will only re-occur.
cheers michael
As it's their custom nowadays, it's probably an optional extra together with other essential items like tool kits, centre stands, locking fuel caps, rev counters...:)
Speaking of tool kits...
Is there a "standard" place to stash them on the Speedmaster?
Shifter
Now you can put that suicide shifter you always wanted on it!! Quality control seems to be slipping a bit these days? Always a good idea to go over all the N&B on the bike when you get it! They left the axle nut looose on mine when I got it! I think someone was doing a chain adjust @ lunch time & forgot? Coulda been a VERY costly lunch for them!!
