1 - 3 of 3 Posts
I read that some have used a 70/80 Watt headlight bulb in the TBS.
I have a 2000' TBS and I bought a H4 70/80, 2500k yellow bulb by Nokya.
I think the stock is 50/60 watt.
Am I going to blow anything up by installing a higher wattage bulb?
Has anyone used a higher wattage bulb for thier headlight?
If for some reason the light dims when you idle, then its drawing to much. The fix for that is using a relay to carry the power, then you can upsize the supply wire gauge.
I went with an HID bulb and ballast, less wattage, really bright light. But I've used 80/100 bulb inother bikes quite happily.
1 - 3 of 3 Posts
