I won an sv650 front wheel on ebay, and bought forks, axle, and complete brake system including the rotors, calipers, brake lines, and master cylinder/lever etc from an SV650 forum.
the forks are the same diameter as the bonnies, and all the dimensions are basically identical with the exception being the bonnie trees are .5'' narrower than the SV's.
I think I'll have to have the axle spacers turned down 1/4'' or so, and also play with the rotor & caliper spacing but other than that I think it'll be easy enough.
The rear wheel should fit fine too, provided the axles are the same size...which I'm going to just guess they are. :-D We shall see.
I'll have to flip the rear wheel around to put the cush drive on the right and the brake on the left, and also I need to figure out what size chain the SV uses to see about sprockets. These wheels are symmetrical so it will still look ok.
I saw Thrux-ton-up's post about 17'' wheels, and Rodburner's post about never losing any air in his Dymags...and I rode my brother's SV this weekend... Dual discs rule.
I'm thinking the whole ordeal can be done for under a grand. I'm in the hole about $500 now and all I'm missing is the rear wheel, but I'll likely have to buy tires and a chain, maybe some sprockets too, or do some drilling/fabricating adapter plates...
Gotta figure out how to drive the speedo too. Anyone know how the SV speedo is driven?
