1 - 13 of 13 Posts
I've started looking into a new chain, but I'm finding this more difficult than I expected. The owner's manual specifies the OEM 'Regina 136 ORP 114 link endless chain'. Buggered if I can work out how this translates to 525, 530 etc.
McLeods gives a breakdown of the meaning of the three numbers, so I could work out the link size with a ruler, but ..
Look, I'm just getting lazy now. Can anyone out there tell me exactly which DID chain I need for my 2002 Tbird? I know there's x ring, o ring, HD and XHD etc. Think I'm after an o ring HD from what I've read over the last couple of days.
You need a 530 chain.
X ring is better than O ring, with an O ring you only get one sealing face but with an X ring you get 4, so it should last longer.
If you are comparing chain specs. then look also at the tensile strength, higher is better.
Cheers, Slinky, just the distillation I was after!
Take a look at the RK XSO chain, the T3 Sport Touring guys like them. High strength x ring & good value here compared to DID etc. I have one fitted now, seems very good so far. Comes with a rivet link so you need a breaking/riveting tool.
I have ised DID chains for many years. The one on my my bike has done over 60,000klms. It is buggered. Will buy the same again.
What do you think of these "screw links"?
I'm also about to buy a whole chain & sprocket kit, but not sure whether to buy the rivetting tool or if the screw joint would be good enough (safe).
Screw link is fine from what I've seen on here.
I see the one comment on mileage, but what's a typical range where people replace them under moderate riding conditions?
I reckon 20k miles or even more from a quality x ring chain well lubricated. It was the sprockets that were showing wear on mine after ~18k miles. I'm sure lube & dust conditions etc. will cause significant variation.
dunno, but mine is dirty and ugly, so it's gotta go ;).
Too funny! I just saw a brush specifically for cleaning chains today.
A few days ago I saw a used Kawasaki sport bike that was immaculate everywhere except the chain. It looked like someone smeared tar on it.
I just took my Legend in for service. They cleaned and adjusted the original chain and said it was fine. That's at 10Kmi (16km). I was going to change sprokets if the chain was worn but they told me it's good for another 10Kmi and go ride the [email protected]#s out of the bike and have fun!
at 16,700 miles I just put an EK 530 O ring chain on, kept the original sprockets...fine at now 17,500 miles...
1 - 13 of 13 Posts
