Hi Thor, I don't recall this from the old days, & I've never ridden Triumphs out of California in the modern times, meaning in last 10 years.
Sticking slides can be hard to test for if they only stick just off idle. One way you can sort of test this is at idle pull up on the cable housing at top of carb. Just pull gently & feel the cable play. Video this on your phone in detail so you have a baseline. You can hear & feel the tick when slide drops down more quickly. By the way at idle you should have a little cable housing play.
Sync carbs your favorite way. Then after that, warm motor well like 15-20 miles & set mixture & idle rpm. California fuel will allow stalling hot at stop lights suddenly if you go to slow on idle. I like to be about 1050 ish. Really hot weather when the gas in tank is really heat soaked I'll still have to blip throttle at times or hold idle 1500 or so with throttle.
There is no provision for fast idle on our bikes. Choke may be needed for better running cold after start up. Triumph choke doesn't respond like a car carb butterfly choke. If you are using choke experiment on how much choke to give after motor fires & as motor warms. None the less, you'll need to hold throttle to keep fast idle until motor warms well. Depending on ambient temperature on many bikes it's a good 3-5 miles before you can trust idle. Depends on your mixture & hot idle settings.
Here's an oddity... I cannot explain why. But is 100% repeatable on all the bikes I've worked on & did a longer road test. The exception is Trispark equipped bike. Trispark controls idle rpm by modifying timing.
I'll get on freeway or a high speed road like 62mph and above for some minutes. A good example is I'll ride 15-20 miles on the freeway at the above speed. I'll pull off freeway & at stop sign bottom of ramp motor will idle about 300-500 rpm faster for a short time. 3-4 minutes. Then as motor cools in the slower riding the rpm goes back to the expected setting. Back in 70s this exact same route I don't recall motor doing this. It's not just bike, they all do this. Except the Trispark. Boyer, Pazon, points bikes all do this. Goggle this, it will look flatter than it is, but you'll see route from Pleasant Hill. I live near our little downtown.
I'll get off of freeway in Oakland hyw 13 at Lincoln exit. At stop sign motor is idling way too fast. I'll go down westward on Lincoln, compression braking all the way down the hill. I turn left on Delmer. When I get to Delmer the idle is a bit too slow as motor is overcooled from the down hill. In a few blocks of using normal power on the flatlands the idle is back to my setting. Again, all the bikes I've ridden this route or similar route to this. Only Trispark is the exception.
Again, California fuel is different that most of USA. So after some careful carb syncing & mixture, idle rpm adjustments, you may be experiencing something that is normal?
My bike has done this with the old carb, with the new premier carb. Sadly I don't recall if it did this on leaded 110 race gas. I'm running points. I shortened my AAU springs & have verified they pull back strongly. But the original springs & shorted springs didn't change this at all. Of course as rpm goes above idle, the timing advances. Advanced timing increases rpm. So you get an extra increase of rpm from the timing. Looking at timing marks in garage on hot motor, this advance increase is part of the extra high rpm after freeway ride.
It gets more tricky. In warmer weather beginning at 75f or so, & gets worse as ambient temp increases. After maybe 4-5 stoplights in city a block or two apart the motor doesn't idle faster, but tends to idle slower. Especially with hot fuel in tank. The hot air from nearby cars blows on us. The tank & fuel load will get very warm to the touch. Especially at 95-100F. Stop/go freeway rush hour traffic is very bad for this also. I'll occasionally get stuck in this for 2 hours. An hour is very common. Lane splitting (threading) is legal in California, which cools motor. But I'm afraid to do it. I've seen many bikes get hit by cars lane splitting. Happens almost every day here. So I know what these bikes do in everyday riding in California. I find Triumphs love 60f days. They do their best at 60f.
Don
