141 - 160 of 171 Posts
Discussion Starter · #141 ·
Doing some research and the brass nuts are from LowBrow Customs. There is a hollow hex tool that is supplied to tighten the springs down. I contacted LowBrow about getting the tool.
Would you advise me using brake cleaner on the plates and friction plates? Previous owner was sworn to Valvoline VR1 (which isn’t JASO spec) and that was my first suspicion that clutch was slipping.
*Stuart- the clutch spring tool I purchased is for what a typical Triumph clutch spring nut should be, not this fancy brass job that I discovered. When I first saw these nuts I was thinking *** are these?
Petrol worked on mine years ago. I'd expect anything that degreases would work as long as you wash it off properly afterwards so it doesn't get into the engine.
Hi Thor, Clean plates with gas & a toothbrush. Dry with cloth & set aside to dry. Oil plates per Hyde instructions. I always oil plates.
Your spring nuts use a normal Allen wrench. Likely American, but might be Metric? Measure it best you can & go to any automotive parts or hardware store & by the multiple sizes one. Cheap one is fine.
I have to personally compare your nut’s with original nuts to know where “baseline” is Normal nuts are top of dome flush with stud. End of day the original type nuts might make your simpler.
I thought motor oil was discussed earlier. Use any brand you like.But… you’d better make darn sure it’s 100% wet clutch compatible. Dedicated motorcycle oils are specifically designed for wet clutches.
You use wrong oil you’ll NEVER EVER cure slip.
Don’t sabotage yourself with wrong oil. I don’t care what prior owner did. How’s your clutch working now? Not good! Again I don’t recall what Valvoline oil you were using. Until you get clutch figured out, use real motorcycle oil.
Don
7 plates as advertised. No clue on how much material there should be but it’s pretty thin. You’d think the clutch material would cover the whole bare plate.
The not covering the entire plate is deliberate, the thinner and further out the friction material makes the average point of contact further out from the centre. The greater distance from the centre is the equivalent to a lever, the longer the lever the more power you can transmit through the clutch for any given spring tension.
regards
Peg.
Discussion Starter · #145 ·
Don
I'm using Castrol Actevo 20W-50 semi-synth which is made for motorcycles. I called LowBrow about getting the tool they use for the brass nuts and they are sending me one in the mail. Good customer service that Todd at LowBrow.
The PO was using VR1 oil...
· Premium Member
FWIW, I have used Valvoline VR1 in a couple of OIF bikes I've owned with no negative affect to clutch performance. I've used SAE 40 or 50, as well as 20w-50. I'm not sure what "real" motorcycle oil is, LOL:D, but I think I understand what Don is implying. In those same bikes I also used Mobil1 V twin 20w-50, clutch performance was the same. Lately I've been using PennGrade as per Franz and Grubb. Their website recommends following what Triumph recommended at the time of your bike's manufacture. So, as per F and G, if your bike's owner manual says run straight grade oil, then run straight grade oil. If it says run multi-grade, then run it. I'm not saying that's the final word on oil, I'm just saying that is what Franz and Grubb have posted on their website.
FWIW, I don't own either of the aforementioned OIF bikes...
Hi Happyfeet, Good point. What I can real motorcycle oil is oil that is specifically formulated for motorcycles with wet clutch.
There are other types of oil not motorcycle specific, that work fine for motorcycles. But... you had better be darn sure they will not make clutch slip. Franz & Grubb like PennGrade oil. They are experienced & smart. I wouldn't use mono grade oil in my riding conditions. Can be 60f in the morning & 110f in the afternoon. Most 30w looks at thin as water after riding 50 miles in 110f. I can (will) make oil light wink on at idle of 900-950 on most bikes. Multi grade oil is real & works.
Valvoline sells many types of oil. VR1 is a racing oil. It specifically states on the Valvoline VR1 website it contains friction modifiers. Many friction modifiers have proven to cause clutch slip. I'm surprised that VR1 didn't cause clutch slip.
I'm not saying T140 has more power or is faster than T120. My observation over several bikes it for whatever reason T140 will slip a clutch under heavy load where a 650 will not. This includes 650s with 750 big bore kit.
Maybe it's the steeper rod angle of the short rod motor that gives more torque at a certain moment that causes this. I was pondering this very thing on todays ride, as John was with me on his '69 Bonnie. It has Hyde 7 plate with stock steel pressure plate, 650 springs. I set clutch springs to the formula, Easy lever effort & no slip. My '73 Tiger is set to the formula, easy lever effort & no slip. But my springs have about 1.5 turns deeper than Johns. His clutch is actually easier to pull. Mine is still easy though.
Don
Hi Newsh & Thor, Good idea how to work out formula. This works with even very, very worn plates.
7 plate friction pads look worn out when new compared to 6 plate. So long as you have visable friction material with zero glue showing through, any where on the friction pad surface, they will still grip. How long will it be before worn to the glue is a different story. If clutch is set up perfectly like it should be with no slipping the very thin friction pads will last a long time. Many thousands of miles. 15K+. Even minor slipping under load will very rapidly wear the friction pad to the glue.
Obviously if the friction pad is worn off it will slip. I know some clutches are all metal to metal, but these can't do that.
We'll back up. There is a little hitch in the way the first pad might fit into basket... The friction pads even new are very thin. Original Triumph basket has a fairly sharp square corner at bottom of basket. This allows the thin pads to nest properly into the back of basket. All the reproduction baskets I've seen have a rounded radius at back corner of basket. So the metal of the friction plate fouls the radius & first pad doesn't lay flat. Now first pad is in a little crooked. All the rest of the discs end up a little crooked. The tend to slip & drag as you might think. The cure is to chamfer the outside edge of first friction plate such the plate lays perfectly flat with a little wiggle room. Of course the thicker friction pads of a 6 plate kit hole the steel of plate above the radius.
On a used clutch as you have, I go through the bunch & find the most worn friction pads. I place that plate in first, worn side to basket. However, you must be extra diligent to chamfer it as it's even more likely to foul the radius. This is very important stuff. I'll show so photos.
Now that's out of the way. Take all 14 of you plates after cleaning & stack them all up in order you'll assemble them. Squeeze them tightly with one hand & measure thickness of the stack with vernier calipers & record. Do this around the stack in 3-4 places & average the thickness. This called stack height. Nominal stack height is average of 1.400".
A new Triumph cork 6 plate kit of all 12 plates will be about 1.400 thick. That's where that nominal comes from.
Then factory tightened spring nuts flush with end of stud. Now we have 2 know values.
I expect you Hyde pack has taken some wear. We could figure this out if I knew your actual stack height. But for this exercise, we'll call the stack height 1.310". I've seen this in real life. So.... Were .090" thinner than nominal. Write that down....
We'll oil & install all the plates. Tighten the nuts down until dome is flush with ends of studs. ( you don't have domed nuts but bear with me).
So just to get the factory spring tension we need to go .090" deeper with nuts. Make sense?
We can set depth gauge of calipers to .090 & measure it or set by rotation of nut.
The stud is 1/4-26tpi CEI (the manual still uses CEI). We divide 1.000" by 26 = .038 rounded. One inwards turn of nut goes .038 deeper. .090 divided by .038 = 2.4 turns (rounded off). That's going to be a little less than 2-1/2 turns.
So we do that. Only do we have factory spring tension on a 650 spring. Over time I've found that's often not quite enough for long term durability. Another 1-1/2 turns will be very beneficial, yet only increase lever effort slightly.
If I was installing new friction plates I would go an additional turn to compensate for the rapid wear as the fuzz wears off & new plates settle in.
I've found if you use springs that are indeed to original 650 specs with length, number of coils, wire diameter, this formula just works. And works well. The formula also works to compensate for wear on 650 plates.
Spring binding... Since we are starting with pressure plate deeper in the basket by .090, we can go .090 without even exceeding the effective nut depth. You can go several turns deeper with 650 springs before they spring bind. If you want to go deeper while pulling clutch lever, at the same time watch pressure plate stop lifting as you feel clutch lever suddenly not want to move farther yet lever is not to grip. That's when springs are bound.
Also... Thust washer.... As thrust washer wears, it gets thinner. The basket moves to right in comparison with the cush hub. The cush hub holds the studs. So now you have effectively lost spring tension. Comparing different makers of new thrust washers, they vary a good .010". Some new are sold that are thinner than removed. Keep this in mind. Do you need to go a little deeper with nut to compensate for thinness of thrust washer. I'll only use Kibblewhite C630 thrust washers anymore as they are so durable. There are a few makers of solid "bronze" thrust washers. They are not all created equally!! I've been disappointed with all but the Kibblewhite. Unless you know seller is selling genuine KW, you must buy directly from KW. Don't be fooled, put the beveled side towards basket or it will fall off shoulder.
Thor, unless Todd can tell you exactly what part of his Allen nuts are where Triumph's dome is, you'll be doing trial & error setting nut depth. If you invest in original version nuts you'll be following a formula that does work well. How much does the original nuts cost. Is the cost worth knowing what works or not. You'll decide that. Those nuts were made for somebody that had a piece of crap nut tool that skipped, & damaged head of nuts. Or user had good tool & let it slip...
I can tell you, you follow this formula with the proper motor oil, which you say you now are using the clutch won't slip. If it does you have very bad wear inside the cush hub & it's pulling the plates crooked, separating them under heavy load. The spider wears much more than back plate. New cush hub generally has about .012-.017" end play fitted to basket. When end play gets to about .030" you may be seeing problems. When end play gets to .040+ it will do odd things like slip at times & not others. It can also start to drag.
The photo shows how deep this nut needs to be. This was will all new Aerco friction & steel plates. I expect you'll be deeper. This photo was with first fitting to test the steel plate with Aerco. After a 100 miles I installed the large diameter Britech alloy plate. The MAP plate replicates the operation the Britech gives. Britech is no longer made.
Also with new plates, trial fit sliding on grooves, they may (will??) need a little filing to slide freely.
Don
Thor, Here's where the spring nuts get torn up... The factory springs may or may not have chamfered end... It seems many of the older ones from later 60s did. The T140 has very sharp edge on spring that cuts into nut head. Triumph manual states use a knife to free end of spring so nut will unscrew. You every try that? Now way have I had success with thin knife. Especially if nut was even a little deeper!
Here's the trick. Take a higher quality awl or the like. Grind the point as thin as you dare. Find end of spring using flash light (& I have to use my really thick glasses!). Push the tip of spring down, then loosen nut & pip will pass over tip of spring. Do it until the pip quits catching.
I 100% of time chamfer the tip of spring. Now you can just force the screw & pip will pass over end of spring. Yet the pip will still be held by spring. I've done this to many springs, every last one I've removed or replaced that wasn't already chamfered. Here's a how to that I use. I generally only do top end, but make sure you put chamfered end up.
Don
I finally found the stack height measuring photos. You can see this is Hyde kit. Make sure your calipers are sitting on top of pad, not in the groove. I finally moved up to digital vernier about a year ago... Vision demanded it! Todays ride was only about 63 miles. So many good routes still closed from storm damage. I was thinking how good these clutches work once set up properly.
Don
Discussion Starter · #154 ·
Thanks for all the info! I have plenty to do and check before this tool shows up. I may end up going back to stock spring nuts and possibly that MAP plate.
Regarding the billet plate-is it the same height as a stock pressure plate?
Hi Thor, Yes, the MAP alloy is same height as the original. The spring cups drop in the same & the adjuster screw threads are the same.
You simply transfer your spring cups & adjuster screw & nut to the MAP plate.
Don
Discussion Starter · #156 ·
Don
I shoulda done what you mentioned vs following the instructions with the MAP kit.
MAP kit has you cut the pushrod to 10.25”. When I assemble everything and get the clutch springs level with the top of the cups, the adjuster they send with the plate is too long.
Allegedly this ball bearing and screw adjuster makes the clutch pull feel easier. It came with the pressure plate.
Now my pushrod is stuck inside the layshaft (or whatever it’s called) and I can’t get it out. Pulling in the clutch lever doesn’t cause it to move either.
Do I have to open the gearbox now to get it out?
Hi Thor, My fingers says it doesn't make pull east enough to feel the difference. MAP web site says it's mainly for use with dry primary systems. It's the springs & cable lube that will give the pull you're looking for. That will only work with 7 plate kit.
That's water under the bridge now. I'd search for a very skinny magnetic pick up tool.
The clutch rod is 7/32". 3/16" diameter magnetic pick up tools are made, but hard to come by. Here's an example like I use. Sold by tool sellers like snap on or Ebay. Occasionally local auto parts or hardware stores will stock them. This skinny magnet is very handy!
V8 3826 Flexible Magnetic Pick Up Tool, 3/16" head,21.5" long 10 Oz Mag. power | eBay
If worse comes to worse epoxy a 3/16 diameter magnet to end of 3/16 aluminum rod. The little magnets are sold on ebay.
I'd strongly recommend putting the MAP adjuster in tool box & using your original adjusting screw with a new original rod.
If your ball fell into main shaft, could this skinny magnet pull it up & out? I have no idea, maybe. I'd not remove the outer trans cover unless you really have to.
Don
Hi Thor, Here's my tool. 5mm head. Slightly larger than 3/16. I paid about $40 for it from tool network. The ebay one is a bargain. Mine will pull rod from main shaft no problem so long as the right end of rod is not mushroomed. I've used it many times, even with pressure plate installed.
I mostly use it to retrieve broken lower end of clutch cable from trans outer cover through filler hole.
Don
If you push the rod all the way in, with a scriber or a piece of coathanger wire, till the clutch cable goes tight, then slap the clutch lever against the bar with your hand, will the rod not pop out?
Discussion Starter · #160 ·
I could try that... I was pushing against the pushrod with a scribe while pulling the lever and the pushrod didnt move...
