1 - 10 of 10 Posts
Hi I have a 77 TR7V.
The indicators have stopped working, and on further investigation the wiring harness is a mess, most of the wires are red and scotch locks/crimps everywhere.
It would seem like a new harness is in order, and this would also seem like a good point to go negative earth.
At some point (probably not now) I'll go for an uprated alternator & electronic regulator, electronic ignition and LED bulbs.
What sort (date) of wiring harness should I get and what mods would be good at this time?
I want to run LED bulbs. It may be easier to convert to to -ve earth than have to adapt indicators, tail light & head light individually.
Sure, that would be a good conversion to do. However, i am not versed in converting a bike to negative earth, but I would imagine you would have to swap some major electrical components so that they wont get fried when you swap. Have you done a search of the forum to see if any threads have covered this in detail? I am also going to run a search because i am intrigued at how this process would go. Good luck!
Joe
I also want to run electronic ignition & a high output alternator (not that those won't run -ve earth) I want to get to the point where as much of the irritating crap is as maintenance free whilst still being a triumph.
LED indicators & stop light are fabulous from a visibility point of view
My 1967 Bonneville is positive earth with functionnal modern electrical parts:
- BanboMoto-H4D HID 35W
- Tail lamp T120R 1969 with LED conversion for L679 & L917, 12V
- Pazon TwinPlug/cylinder PD2TTP
- Digital Tachometer Koso BA4800R0
- Digital Speedometer Koso BB550B40
- Digital Oil Presure Gauge Glow Shift GS-BD04
- Lucas Powerbase High-Output 3-Phase Alternator kit 180 watts
- Light/Flasher switch Honda CT70
- Four flasher complete from Honda XL600R
If you want to convert to -ve earth, you will not be able to use an off-the-shelf harness, as they will all be +ve earth.
Mark
'79 and newer
Triumph changed to negative ground in 1979. Bob
1 - 10 of 10 Posts
