1 - 3 of 3 Posts
So, I need to replace my the rear master cylinder on my 2012 Thunderbird Storm.
Official triumph parts run $260-270. Can anyone recommend a less expensive quality alternative?
I saw some cheap ones from China on eBay but I'm skeptical. Thanks! -Tom
Do you need to replace the entire master cylinder assembly? A new piston set is only $50.
3 things you should not cheap out on: helmet, tires and brakes.
Papi,
I bought rebuild kit from 2wheels pro. Will say getting it pumped up took quite a will.
good luck
Dan
1 - 3 of 3 Posts
