1 - 10 of 10 Posts
Sorry, this may be a little off topic but I am considering using a later Japanese frame and putting in either a 500 or 650 unit twin engine into it. I cannot seem to find anything on the net which shows the physical dimensions of the engines (max width, height etc). Does anyone have any info on a site that may show these dimensions? Many thanks. Glyn.
(I am on [email protected])
Welcome, Glyn.
I took the liberty of moving your post for better visibility.
I don't have any info that will help (yet), but you're sure to get a good answer soon (probably from someone located where its raining, because it's great riding weather in most places right now).
Many thanks for organising the thread. I've been mulling over this for a while and am reasonable OK on the bike mods in a DIY/hacker sort of way. Done a Weber IDF conversion on my XZ550, drilled discs and OK with a welder etc. I've been looking on the net but can see no evidence (so far) of anyone putting in a Meriden twin into a nice modern (not too modern) Japanese chassis. My XZ550 Yamaha basically has a Pantah copied frame with great brakes and a nice mono shock. They are cheap as chips down here second hand. It has nice down tubes (bit like a Seeley), from which motor hangers could be made easily (or looks like). It is a shaft however so will need a bit of work on the rear end. Lots of chain driven Yamaha's of that era had common or similar parts so that should not be a biggie. The closest thing I've seen is a Commando motor in a Seeley frame. That would the the look I'd be after. Prob use a soft 650 or a 500 to keep the vibes down and make it a nice everyday ride.
Now you're torquing. I hope that A65 motor vibrates alot less than the one I used to have, else it'll be putting some stress cracks in that nice frame. Nice conversion however, seems to fit nice and snug in there. Ta for that.
Have you considered a replica featherbed frame? I am pretty sure there are frames made now with mounting lugs for specific engines.
Discussion Starter #9
Yes that would be the easy route and lots of people have done that. I thought a mix of an 80's decent Japanese steel frame/ good brakes etc with a late (hopefully reliable) Triumph motor would be a bit unique. The A65 motor has the advantage of being nice and compact however, I can see when that would be a good candidate for a transplant. Being new to Triumphs, I have no idea even if the 650's/750's are much larger than the 500's in respect of case length and width? The early 70's 750's seem to be the commonest/cheapest here in NZ. I've read that the build quality wasn't a good as the 650's however?
1 - 10 of 10 Posts
