1 - 11 of 11 Posts
Hi everyone,
Not quite sure what I've got here but I know it's running a Triumph 1961 5TA motor in a Greeves frame but as for the frame I've no idea. Has anyone got a clue what the frame could be off. The down frame/head stock is a solid aluminium casting.
Wheel Tire Fuel tank Automotive tire Automotive fuel system
Tire Fuel tank Vehicle Automotive fuel system Automotive tire
Wheel Tire Fuel tank Vehicle Automotive fuel system
Bicycle part Bicycle handlebar Rim Bicycle tire Automotive tire
· Super Moderator
Hi Glyn,
Looks very similar.
If you look just at the index of Greeves motorcycle images on the cybermotorcycle site, you'll see cast ally front downtube, leading-link forks and blue paint were common to all Greeves models for years ... :cool: From https://en.wikipedia.org/wiki/Greeves_(motorcycles) :-
Motorcycle production began in the autumn of 1953 and the new models featured a unique frame with the steering head and a massive front down member combined in a large 'I-section' cast alloy beam, cast in a new light-alloy foundry that had been added to the Greeves factory. The tubular frame member was inserted into a mould and the main frame was cast around it, ...
Ime, the "Grumph" combination was relatively common in GB at one time - Greeves used many Villiers engines, Villiers stopped motorcycle engine production in 1968, Triumph had stopped producing the 3TA and 5TA after '66, the Tiger 90 after '68; there were always lots of Triumph twin engines in breakers so, when Greeves and Triumphs were just "old bikes" ... particularly if you wanted to go green-laning but didn't want to pay for a Yamaha or Suzuki 175. I contemplated one in the 1980's but, by then, the Japanese 175's were cheap and it was pointed out to me that they'd be a lot lighter than a Grumph when (not if) one of them fell on me ... :cool:
Hth.
Discussion Starter · #7 ·
Hi Glyn,
What (little) I know of Greeves frames, ally front down'tube' casting is at least regular, if not standard. Anything that looks like a model code in the frame number?
Managed to find the number on the frame. 61/3203 with a seperate E stamped lower down the casting but still no help as to which model it's from.
· Super Moderator
Hi Glyn,
:cool: Ime, certainly Google's internet search engine is a wonderful thing ... I entered "greeves frame numbers" into it, the first link it returned was "Identify your Greeves" on the Greeves Riders Association website - specifically a table of Years, Model codes, Names and Types, Engine Capacities and Makers ... and Frame number prefixes. I scrolled down the table watching the data in the "Frame" column, I found "61" almost at the bottom of the table, it appears to equate to a '71 380 Griffon scrambler but you might wish to confirm that on the club's forum, as the text above the table invites readers.
Hth.
Discussion Starter · #9 ·
Hi Glyn,
Hth.
Hi Stuart,
Yes I found the same site earlier but the frame numbers are a bit misleading. Mine definitely seems to have the roadster rear sub- frame that dips down towards the number plate bracket but which roadster is any ones guess. I have been told that 61/3203 refers to the year and how many were made in that year.
Glyn.
1 - 11 of 11 Posts
