1 - 15 of 15 Posts
Hi everyone.
Posted my hellos on the new members page a couple of days ago, but thought I would do it here too, seeing that I just took Delivery of My new 2001 Sprint RS. Can't wait to put a plate on her tomorrow and take her for a ride. Still waiting for the snow to melt but the roads are clear. I'll be looking for some advice about her seeing that she is my first Triumph. Please feel free to give my some pointers on things to look out for.
Thanks:D
Gen 1 or Gen 2???
Keep the fuel Tank breather line (s) clear....they clog easily
Keep the battery at A1 condition at all times
Check for the fuel connector recall......has been done
For piece of mind replace the fuel connector IN the Tank/fuel pump plate with a metal connector....this part is NOT replaced as a recall, but can and does break with disastrous consequences.......
Enjoy THE best 'sleeper' Triumph in the whole range........
Feeling like a real newbie now...I did not realize there were two Generations for this year of bike. Please elaborate.
The recall has not been done but I have researched that one, so I will make the call to get that fixed. sounded like the plate was fixed in the recall ID#50591. I'll watch for that.
Dealer installed a new battery, so I'll keep an eye on that.
Thanks for the Info.
Fuel connector No 2, the one IN the fuel tank pump plate does NOT get changed in the recall.........
It's REALLY worth getting it changed to a metal one!!!!!
2001 should be a Gen 1 bike. It is best to replace the fuel fittings on the tank, or at least to order them ahead of time so you have them when the plastic ones break.
-Kit
Welcome. I'm new here as well, with not one but two triumph triples. I just ordered two sets of the correct metal fittings from this place yesterday:
http://quickcouplings.net
Tank side:
LCD10004BSPT - 1/4 BSPT Valved Coupling Body
3/8" for the return line
LCD23006 - 3/8 Hose Barb Valved Elbow Coupling Insert
1/4" for the supply line
LCD23004 - 1/4 Hose Barb Valved Elbow Coupling Insert
If the recall has been done (aluminum connectors on fuel hoses), all you need are the LCD10004BSPT and LCD17004.
The BSPT part screws into the plate itself, the other one goes into the end of the hose attached to the plate. The plastic elbow that attaches the hose to the plate is made of a different material that holds up much better than the QD fittings.
-Kit
Congratulations etc, hope you get to ride this weekend and the temperatures higher and the snow lower than here.
Rgds Mick
I no longer have my Sprint RS. It was a Gen 1 - intense orange, black frame, grey engine - but remains the only bike I've ever owned that I truly miss. Three brilliant Triumphs in the garage at the moment but I’d happily have the (ie my) Sprint back, in place of one of the current ones if I had to. I’m sure you’ll love yours. The E-Type of motorcycles!
CanberraR3 - you responded to an eight-year old thread - but hopefully the OP is still enjoying the bike!
He has only four posts, though...
So you used the search function at least!
Sent from my SM-G955U using Tapatalk
1 - 15 of 15 Posts
