Status
Not open for further replies.
1 - 20 of 463 Posts
Driving South on the 405 Freeway in Irvine California at about 70 MPH traffic started to slow, I stood up on the pegs to look for an opening ahead and bang!! My right foot was standing on nothing the left foot-peg fell off onto the freeway and I lost control of the bike.
It took a huge effort to keep my foot from hitting the ground at 70MPH and keeping the bike upright. I swerved across a few lanes before I could regain control and slow down and stop safely. Went back and retrieved the foot-peg from the roadway.
The bolt had sheared off right at the point where it extends from the clevis into the bike. There was no reason for it. Never dropped the bike, no sign of rust on the bolt, I did not hit a bump or jump up suddenly just stood up gradually like I usually do to look ahead when approaching slower traffic. I weigh less than 250 pounds. There was no reason other than a manufacturing failure. The sheared bolt is clean and shiny it just broke for no reason.
If I had not recovered from the bolt failure crashed and died the authorities would say another biker just went down on his own and overlooked the sheared off foot-peg as a symptom not the cause of the crash.
Dang, Triumph what kind of steel are you using for critical parts? There is no SAE stamp on the bolt, it may not be hardened or conform to any standard. This is a real issue for us riders and a liability issue for Triumph. I am going to contact Triumph what they say about the failure of this critical component. It should have been tested by Triumph prior to me riding on the freeway with my less than 3 year old bike. I will post the response on this site if I get any.
The drawing below is for the rear footpegs but it'll do for this question.
Did item 11 really shear off or did it come adrift from the "U" shaped bit?:
When I replaced my pegs for Oberons, I did find that the circlips the factory had fitted (item 6) were not tempered, just hardened. When I tried to replace them, one just shattered into 3 pieces...
See last photo on this post:
http://www.triumphrat.net/twins-technical-talk/166959-oberon-touring-footpegs-for-bonneville-se.html
Here's another near-identical case where the bolt has broken, worth reading Prop's advice on post 6:
http://www.triumphrat.net/twins-talk/104282-broken-bonnie-footpeg.html
We've also had a fair few snapped the footpegs themselves, not surprising as they're made of some sort of monkey metal.
Wow - I'm also interested in seeing detailed pictures of the failed hardware. If you could post these it would be much appreciated. Great job in recovering control of your bike.
Glad you are ok.
kj6tk
Thanks for sharing, im glad you were able to stay upright it could have easily ended up as a sad story. These sort of things are a concern for everybody. Cutting corners and putting peoples lives at risk for the sake of money is a problem with todays mind set, give them a stir for us all.
Cheers Klem :mad:
Seeing as I also have a 09 SE like the original poster, and I'm also in the habit of standing on the pegs (not at 70 mph like him though...:eek:) when travelling over humps or rough ground, I got a bit worried.
I've had a look at the footpegs fixings and, although they're not the world's finest, I can't see how a shear load sufficiently strong to break the stud can be applied.
The peg is held to the frame with an M8 stud and self-locking nut. The stud is welded by 3 spot welds to the U bracket. Shear loads should be taken care of by the two stamped 5mm dowels and the friction created by the tight stud on the two contact surfaces (0.81 sq Inch in area). The stud should be free from these shear forces unless the nut is loose and the stud threads have to bear the brunt of the riders weight.
Before this happens the rider with a bit of sensibility would notice the wobbly footpeg I would have thought, but you never know.
I'm including a couple of photos to encourage others to give us their opinions on this. They're for the passenger pegs, but the fixing method is the same.
A potential problem I see is Triumph used a screw (threaded the whole length) rather than a bolt (Part of the shank unthreaded) which would weaken the mount.
I stand (just getting the bum off the seat) on the pegs frequently at highway speeds over bumps. Lucky the Thruxton design is different and appears at least to be much stronger being a solid casting. Although the pegs themselves are still a bit of a worry as I'm using FZR type ebay ones. They seem to be solid enough so far.
Let's hope the OP doesn't abandon the thread and provides us with more data and possibly a close-up photo. We might be able to work out a likely reason and think of something to prevent this sort of thing happening to others.
You sir are an experienced rider to have recovered from something like that.
My best guess would be that the nut was overtightened at the factory , thus putting the stud under high tension. When weight was applied it increased that tension enough to make it "pop". No need for a high tensile stud in this application; but if overtightened then this is what would happen.
I'm watching this thread for more information. I ordered MFW pegs for the front and Oberon for the back, but we still have to use the OEM clevis, so I want to see what the resolution, if any, is.
Watching this thread as well.
Glad you're okay...and wow. It's one of those things you don't think about much, and I'll be checking my own, for sure.
1 - 20 of 463 Posts
Status
