Hi some photos I forgot to add parts out on my gearbox that were found bad changed...
Shift plate,forks n rollers,also changed spring and plunger out of my 1970 t120r parts motor new bearings were used in rebuild.
Bearings were probably new 71 years ago.
My shift plate had seen better days.
My old cork insert clutch plates put new
Barnett plates were used in this rebuild all new.
Have a new sump plate to install with magnetic plug will be handy.
Gotta rebuild my oil release valve has been leaking the rubber tube cost a whole 1.50
70-2793 its probably 71 years old.
