Hi NewbornLobster, I have great interest in this subject. Exactly what brand & model meter are you using? I'm trying to figure out which meters work & which don't.
Would be helpful if members would say what meter they use that works & what meter doesn't work. I mean digital meters.
One in USA for sure goes crazy is Harbor Freight Cen-Tech. $6.49 or sometimes free on give a way promotion. We used these at work all the time when there was risk frying the meter. Never used it on sensitive computer circuits. I had maybe 6 or 8 of them on free give away. Over time smoked them all. It worked fine with motor stopped & ohm meter. Amp meter worked good, but not very much amps.
My other meter is Extech MA200. About $80.00 from Fry's electronics. They don't sell it anymore. Mainly made for AC house wiring etc, but works perfectly for Triumphs running or stopped. I've even zip tied it to bars for extended road test to observe actual voltage during all day ride, city & country.
I've used various models of Fluke meters. All worked motor stopped & running. All these were in the $200-500 dollar range. Not needed for old Triumphs, but they are very nice. Fuses can cost $20+.
All analog meters work fine, but harder to read accurately. I have old Radio Shack analog multi meter. Kind of hard to read on 20v scale. When you are testing Zener diode you want to see volts very closely. Separate ammeter is needed for Zener test that is also accurate.
I really don't know exactly why some digital work, others don't. I don't know what price point becomes the ones that work?? Or is price not a factor??
This is why I want to know what meters work or not. So owners can test voltage running without breaking the bank. Worst of all is buying meter & it doesn't work. No returns on electrical tools as they say.
Regarding Triumph electrical system, it's about a primitive as it gets. Very basic, very simple. The alternator is so low output it just barely keeps up with demand, so long as motor is spinning over at faster rpm. Above 3000 it's not so bad on out put. City riding with many stop lights is not so good. Turning on headlights with original bulbs the alternator is about maxed out. City riding can be a struggle to keep battery charged. Really the alternator puts out 100% it can depending on RPM. Output directly related to RPM. Again max is not much. If the voltage reaches a threshold of about 13.5v the Zener becomes active & starts passing current to ground. The current is converted to heat. There is no voltage regulator. Just the extra is sent to ground. With original bulbs lights on, you'll find very little is sent to ground even at higher rpm. That is how close output is matched to consumers. You get a very light weight system. Very simple low cost bridge rectifier (diodes are built into the cooling discs). A simple Zener to take extra current to ground. Very low cost & simple. Since charging system is so weak at lower RPM a good battery is very desirable.
There is no provision for electrical interference like a car would have. No need. No radio, etc. This allows for solid wire spark plug wires with no suppressors or resistors. As was stated above this is why it makes some meter go crazy. I don't really know.
Don
