I was just checking the bike (2000 Thunderbird) before a ride and one of the screw parts of the mounting tube just fell off. So I just have one bolt holding the directional signal and headlight on the right side. Is there a method to fix this mounting tube without taking the whole staunchion assembly off?
Remove the top clamp, leave the forks in the lower clamp.
  • Like
Reactions: irbyma and NeilD
Once you get the tube off you could repair it like this -
Drill the broken bolt out and file the hole square -
Then get one of those round headed stud bolts from the hardware store and file it flat, like so -
You could then either glue it in with epoxy or super glue or something. The square hole stops it from turning.
Problem solved :).
Check the condition of the rubber bushings between the fork tube and headlight tube mount. One of my side plates cracked due to deterioration of the bushings. I could see this causing the bolts to shear also.
U.S.M.C. "Semper Fi"
POW-MIA "You Are Not Forgotten"
