thanks
it looks like it requires some modification to be able to use it with our triples........
Cheap method to raise the front end of a 955i
If you are looking to get the front off the ground (and you have a center stand) for fork oil or tyre change, then I have the cheapskate answer...Two sturdy buckets filled with sand and a tie down strap across the rear end of the bike. I did it last week and it worked a treat. For good measure I filled the top box with bricks too. It didnt budge at all!
Dave.
