Doing a mock-up with the motor and frame I have 2 questions. All the hardware lined up nice in the appropriate holes. I'm thinking the bottom 7 7/8" stud should be tightened first? Second, I noticed with the engine plates snug on each side everything looks plumb and square, but I have a space behind the plate where the shouldered nut tightens to the swing arm casting stud. The left side has a .060" gap and the right has .030". I plan to put a shim in there so the nut can be torqued properly. This area doesn't look or would have a need to modify, so I'm writing this off to 50+ year old production line saw-cut tolerances. Any thoughts? Gary
