1 - 3 of 3 Posts
I just got off the phone with Mathias at Spiegler and he was not sure, so I thought I'd ask here. My Chonoclasic will be here tomorrow (hopefully) . Does anyone know if the standard wires that hooked up to the original Thruxton Tach will work with the Motogadget Chonoclassic ? Or Not . Otherwise , I must connect up to the negative side of the primary coil. Based on some of the schematics I have seen here, hooking up the rest ie, (H Beam, Turns) etc should not be a problem. Any thoughts or help will be appreciated. Thanks, Sutty
Thanks Brother, I'll give it a try and see... I hope that it works, save a lot of time and would be much simpler.. Thanks, Sutty
1 - 3 of 3 Posts
