ok i snagged the tuneboy and zard exhaust from geof3
almost paid for it too
any way i will have to buy the key for the tuneboy .
i am surmising it works like this
the software is free to download
the hardware is a cable to go between computer and bike
the key enables the software to reprogram the ecu on the bike ?
what is the difference between tuneboy and tune edit ?
i really cant wait , i am not 100 percent on the zard can , but the header and midpipe part of the system are worth what i paid for it
i can always change the can
who wants to buy a complete stock exhaust ?
you are on the right track. tune edit is is the part of the tuneboy set-up where you load new fuel maps make a customized fuel map correct your speedo error raise or lower the rev limiter among other things. tune diagnostics is like a virtual dashboard. you can see rpms and see what your sensors are reading like temps and stuff like that. tune diagnostics is where you can read and clear any error codes. tune diagnostics and tune edit are both part of the tune boy software. you can do much moer but thats a simplified run down
Bill,
All of the base tunes are included in the CD. I'll also send you all of my tunes that have some things tweeked for fun. I also geared my bike to 44t in the rear. I have a tune for that as well.
When you get it, we can discuss all the cool stuff it can do. It's fun to play with because you can see everything the motor is doing in real time. You can also diagnose and correct computor errors. It's the closest thing to the Triumph computer you can get. I think it's actually better, simply because the interface is so cool and easy to use.
Henry, I might be interested in the header part of your factory system. I want to build a custom low mount, and if for the right price I can avoid cutting my system up, I would seriously consider it.
