Hi everyone.
A wiring issue, trace and fix that might help someone.
While cleaning and tinkering( I ride all year so lots of that needed) I noticed the clock lights weren't working. Mmmmm. Tried my default diagnostic technique- wiggling the wires:laugh2: No luck. Not surprising really !!. OK. check the fuse. AHA I thinks. New fuse fitted and we have lights, well, nearly. One is not working. So, a little while later after removing fly screen, headlight and clock cups I can get at the offending bulb. Its "blown". New bulb fitted and, oh, still not working. Now its time for the trusty Multi-Meter. I unplugged the connector in the head light bucket from the loom and checked for continuity on the wire. No luck. Broken wire or iffy connector I decide.
I start cutting carefully the loom, wiggle a few wires, and out comes this.
http://www.triumphrat.net/attachment.php?attachmentid=532226&stc=1&d=1510243971
More cutting and the spaghetti nightmare appears.
http://www.triumphrat.net/attachment.php?attachmentid=532226&stc=1&d=1510244433
I find the offending connection, cut the shrink wrap off and
http://www.triumphrat.net/attachment.php?attachmentid=532234&stc=1&d=1510244752
There's the problem. Rather corroded and a bit green.
I stripped the wires, practiced soldering as I've not done it for awhile, happy with the results so away I go. Picture of the finished solder joint ? Not a chance !! LOL. It didn't go very well and I was a bit disappointed. Very lumpy, plastic a bit over heated, but ok. Just.
Everything re-wrapped and put back together and good to go.
Hope it helps.
Jon
Excellent trouble shooting !
Thanks for taking the time posting your pic'c and for sharing your problem and resolutions ! Helps all of us.
Since you have that part of the loom open, I HIGHLY recommend you peel back a little further and solder the green/red wires. There are so many weak points in our loom, but to eliminate all of them, requires a complete tear out. If you ever wire in a RFID, you can tackle that at the time.
But for now, the green/red should be tackled.
Just my .02
Thanks @Back2-2, glad it was worth posting.
@CUP1967. Yep you are right, there's quite a few iffy looking connections in that part of the loom!!
Jon
