1 - 20 of 24 Posts
· Super Moderator
One of the members asked me to create a Reference Thread of quick links to some of the Mods, Upgrades and Fixes that have been posted previously and which apply to the Daytona range.
Thanks Henkka83 for suggestion.
Please don't make this a discussion thread - take any questions on any of the links directly to the link thread itself.
I'll start it off - please add as you find appropriate, whether your own personal work or something you found helpful as you came across in research.
Some of the links may be in other sub-forums (Sprint or Speed Triple) where there is commonality in specific application.
All suggestions listed below this post will also be incorporated into Post #1 to make a complete listing.
OEM Part Number Find
OEM part Number Locator
T595 Ground Block
T509 Wont Start - ECU ???? (post # 10)
Charging System Diagnostics
Charging System Diagnostics - Rectifier/Regulator Upgrade
Headlight Upgrade
Headlight Performance Improvement
Cibie Head-Light Install
Headlight Cut Till start
Headlight Cut Mod
Starter Power Mod
Starter Power Mod
Digital Speedo Conversion for 97-01
Digital Instruments from 02+ onto 97-01
Speedo upgrade for 97-01 Speed Triples & Daytona
GSXR Fork Swap
K6 GSXR Fork Retrofit Complete
Speed Sender Alternative Solution
Broken Speedo Sender Fix / Also mod for 05+ wheels on...
Quick Throttle
Quick Throttle Mod
Digital Instrument Panel LED upgrade
Instrument Panel Lighting (02-04)
Seat Padding/Cover Upgrade (Great Day to Ride)
GDTR Seat Upgrade
2002 Ignition Circuit difference (NOT in manual!)
2002+ Daytona Ignition Circuit
Fork Selector Shaft Oil Seal leak
The Elusive Oil Leak Mystery - Resolved!!!
Keyless Ignition System
Keyless Ignition - Part Deux!
Chain/Sprocket Replacement
Chain and Sprocket Replacement - Part 1
Rear Hub Bearing Maintenance
Please post a step by step to lube the rear wheel bearings.
Valve Clearance Adjustment (1050 but same for 955 02+)
https://www.triumphrat.net/maintena...ances-part-1-preparation-to-part-5-notes.html
Fuel Pump Fitting Replacement
https://www.triumphrat.net/daytona-deliberations/229379-fuel-fitting-replacement.html
Fuel Tank Leak from Drain/Vent Nipples
https://www.triumphrat.net/daytona-deliberations/111972-t595-daytona-gas-leak-help.html
Clutch Switch Bypass
https://www.triumphrat.net/speed-triple-forum/232829-start-bike-in-neutral-w-o-clutch.html
Installing relay for heated grips
https://www.triumphrat.net/daytona-deliberations/117110-relay-install-for-heated-grips.html
Fuel Bot- Fuel level and MPG Gauge
https://www.triumphrat.net/speed-tr...t-accurate-fuel-gauge-you-will-ever-find.html
Quick Release Seat
https://www.triumphrat.net/speed-triple-forum/184271-quick-release-seat-screws.html
Steering Head Bearing Replacement
https://www.triumphrat.net/sprint-forum/39391-adjusting-steering-head.html#post501700
Raised Handlebar Position (inverted clip-ons)
https://www.triumphrat.net/daytona-deliberations/241049-raised-handlebar-position.html
Header Cleaner
https://www.triumphrat.net/speed-triple-forum/38387-limeaway-pics.html
Full Range Fuel Gauge
https://www.triumphrat.net/daytona-deliberations/636514-fuel-gauge-retrofit-02-06-daytona-955i.html
Easy Clutch Pull
https://www.triumphrat.net/daytona-deliberations/683921-diy-mega-soft-clutch.html
Lowering rear via Sprint Brake Swap
https://www.triumphrat.net/speed-triple-forum/426041-lowering-the-speed-triple.html
Sprag Clutch Replacement Option
https://www.triumphrat.net/speed-triple-forum/746130-possible-sprag-clutch-replacement-option.html
Gen 1 Sprag Replacement Process (with pics)
1998 T595 Daytona 2014 Kawasaki Ninja1000ABS
Google Sky King Products. He's in CA. He no longer has a web site, but you should be able to find his phone number to see if he still has crash bungs for the 955i. I have them on my '98 T595. I will try to find the number.
The owner is John. His number is 858-337-5267 in CA. He makes product to order, he might still be making the bungs.
1 - 20 of 24 Posts
