1 - 2 of 2 Posts
My '78 Bonne had 930 Amals originally, but due to serious corrosion, have installed VM30 Mik's.
The clearances were tight so i cut about 1/4" from the aluminum bolt -on adapter, but also cut the rubber hose coupler to match.
Unfortunately,the rubber piece is now too short and the fitment is not quite as tight as it should be.
Does anyone know where to source a replacement hose without going back to the vendor?
I appreciate any help.
gruntmachine
Hi believe it or not in the old days I use to use radiator hose if that’s any help.
1 - 2 of 2 Posts
