So me America fell over breaking the clutch lever and rear indicator, so I got the tail tidy cos it looked good and less vulnerable. Put the rear assembly on, twist joined (don't like Maunds connectors, was goin' to put on spades) the l/h indicators, they worked. Joined the r/h ones and got a hazard light effect. Disconnected them and tried the left ones again: nothing. No horn either tho the fuse was OK. Put spades on all wires including tail light and nothing works. You get a ring connector for the taillight earth which presumably goes on one of the mounting bolts. ( zero instructions from Maund.) Replaced the fuse anyway and got one toot out of the horn before it blew. Replaced the fuse and nothing. Should've been a simple mount and connect. Probably no connection, but I did a stage 1 tune and remap from TTP before starting on the lights. Hope somebody can help, thanks.
Discussion Starter #2
Problem solved! The wiring out of the tail tidy was backwards, meaning I had to connect live to earth instead of live to live. Never come across this before...
Always read the instructions and look at any included diagrams. Then when things don't go as expected, test and verify the wiring for yourself ;)
Have had similar issues with items over the years.
Absolutely agree, except there were zero instructions or diagrams. The taillight was the same: instead of red to red and black to black it was red to black. I'm expecting the front indicators to be the same....
So the front indicators were reverse wired as I thought. Also pretty obvious that nobody at Maunds has fitted them to an '11 up America, otherwise there would have been 4 spacers in the kit: 2 to bring the mounting bracket forward so the back of the indicators clear the forks, and another 2 to push the indicators out so the wiring cover fits. However, they're on and look good, so that's the main thing. Just a pity that instead of about a two hour plug 'n' play job it turned into a two weekend epic, mainly by having to run to town to buy things I shouldn't have needed.
