1 - 3 of 3 Posts
I have the fog lights installed and plan on getting the heated grips. These come with matching round switches. I would like to add two additional matching switches to the right hand side. I asked my local dealer and he couldn't find any.
Does anyone know a vendor that sells the same kind of switch?
Matching Switches
No I do not.
I do have the heated grips installed and you need to know that the switch appears to be a momentary switch active only when pressing it. That either uses a latching relay or the ECU to activate or in the grips use, switch from high heat to low heat to Off.
Keep in mind that is as it appears to me!
1 - 3 of 3 Posts
