1 - 9 of 9 Posts
Finally got my '53 6T engine running sweetly.....I had to resort to a more modern brand new amal carb.
However now I can start it, and have it running, the next thing is being able to stop it!
It has a BTH KC2-S4 magneto....standard for this era of bike I understand...and I have the cut-out terminal connected to a 'horn' switch which goes to earth. I've checked it's earthing the terminal with a meter.
The terminal had the internal clip missing which made contact with the central nut, so I made one out of a feeler guage.
When I try and use this system to stop the engine....no success. I tried earthing the terminal to the engine casing with a metal rod (and got a slight electric shock whilst doing so) but it still wouldn't stop the engine.
Any possible suggestions?
OK, I have to ask this, because I have seen this happen before... Do you have the mag and the bike charging system wired opposite polarity?
try unplugging your battery, and see if it stops
Thanx for your replies guys......
Attached is a diagram of the cap parts to the BTH magneto...
I replaced the arm '63', which had broken off. Not sure of the parts you mean Paul?
As to the polarity of the battery, I'm running a 12v positive earth.
I assume the magneto is positive earth as the bike would have originally been positive earth.
I'll try disconecting the battery when I'm next in the garage.
Right, I have now tried disconnecting the battery circuit....and this makes no difference.
I have also started the bike with the magneto cover off, and whilst the engine is running I shorted across from the primary chaincase cover (earth) to the central contact breaker nut (No. 58 in the diagramme). There was an occasional spark as I did this but the engine kept running????
I am now very confused.
The battery/generator circuit makes no difference,because it's a separate and independent circuit.
I'm confused too.The centrebolt should be making good contact with the points plate.If you ground out the bolt,it should short-circuit the points and stop the engine.Is there anything stopping the centrebolt making good contact with the points plate,something that would insulate it or cause a bad connection?
Thanx Mr Pete, I'm glad its not just me!
Below it a photo of the points with the central bolt removed.
The bolt is getting a good contact to it.
I tried again, and every time I short the bolt with a screwdriver I'm getting a spark. But the engine keeps going!
Discussion Starter #8
I managed to speak to an extremely helpful guy who rebuilds these magnetos.
He immediately guessed the likely problem...and I thought I would let the forum know, just in case anyone else highlights a similar problem.
On the above diagram, I have the eathing brush and spring missing (No:56).....but you can get a similar problem if the brush is dirty or worn.
New parts are arriving soon and hopefully I'm all sorted!
Methinks Grand Paul was onto that......it's an old trap. Seems to be a fair bit of old dried up grease behind that cam ring, might pay to clean it up & re lube.
1 - 9 of 9 Posts
