Here's my plan: swap out the stock bars on Bonnie with NH M-Bars with Napoleon bar-end mirrors. To accommodate the bar-end mirrors, I would be buying the M-Bars without bar-end plugs. But after burning through two hours or so of my work day reading various posts about M-Bars, vibration, etc., I'd like to do something to reduce/eliminate vibration when I do the install. Here are my questions:
Has anyone used a standard bar snake with the M-Bars, and will it fit inside the M-Bars? (Since I'd be buying the plug-less M-Bars, I assume there'd be nuthin' stopping the snake from sliding through.) If you've used the standard bar snake with the M-Bars, did it help much? I've read posts on the liquid bar snake used with the plug-in M-bars, and some claim it helps, others believe it's a waste of time.
Are there any other effective bar-end weights to use with the M-bar/Napoleon setup? Reviews of home-spun remedies like silicon, sand, wax, lead shot, etc. seem pretty mixed.
