1 - 3 of 3 Posts
Hi All...
I was wondering if anyone could who has fitted the LSL handlebar kit could offer some information?
I am in the process of fitting the top yoke kit change from clip on to flat bars, on 2004 Thruxton. I have mocked it up on the bike but the spacers that’s sit under the you where the clip ins used to sit seem to have some play in them slight up and down movement pad side to side as if the bore is to big!
am I doing something wrong of is it a case of lososing the lower clamp to compress them against the bottom of the top yoke...
Something doesn’t feel right and feel they may rattle if the current fit.
many advice much appreciated
thanks Jim
On my bike the spacers are a loose, sloppy fit. I suppose you could put some tape or an ''O'' ring inside to take some of the slop out. If you do don't use string or anything that would hold moisture and cause rust later on.
Thanks for the reply, I decided to just take them out as planning to lower it in the near future and couldn’t be doing with any rattling around
1 - 3 of 3 Posts
