heliandy,
the rear can be lowered by loosening the adjuster and rotating the ecentric that the axle rides in counter clockwise. this will loosen the chain but if you keep going in that direction the chain will tighten back up and the rear will sit lower. can't tell how much lower but it will do it.
the front you'll need to slide the fork tubes up in the clamps to match the drop in the rear.
I think Oldndumb did a write up in the Sprint forum. You could try a search on it.
