Hi- please can anyone help ? I need to lower my 1998 model Sprint but cannot find any lowering dog bones anywhere. Kits are available for 2000 models off the shelf. I am not looking at spending a lot of money so please no suggestions of buying a shorter rear shock. Perhaps someone might know of an independent supplier...I understand this model/year has splined bearings and not as simple as later models..
Cheers.
Most people looking to lower these bikes flip the eccentrics in the swingarm, then pull the fork tubes up through the triple clamps a bit to restore the geometry. Only downside is the stands: you'll have a hell of a time getting it onto the center stand, and the side stand won't be as leaned over as it should.
-Kit
Thanks for that..It looks like that is the only option. I can chop the 2 feet of the centre stand...shorten the legs and re-weld the feet back on myself.. I will probably get my local workshop to sort out the eccentrics and forks.
The seat is presently undergoing surgery to shave a little off and my local cobbler is adding a thicker sole to my boots !
Cheers for that.
My opinion, for whatever it's worth: Go with shaving the seat first to see if that gets you low enough. That's what I did on my dirt bike. I tried flipping the eccentrics on my Sprint, but the H pipe on my exhaust would hit on speed bumps and such. Not a good situation, so I switched them back.
