1 - 3 of 3 Posts
I know I can slide the upper tubes up the triple trees, but I was wondering if lowering springs would also work. Everything I've read says the forks are the same on all models. The stock height progressive spring kit says it fits all four models. The lowering kit says it only fits the Bonneville and T-100. Is this just a marketing thing or will the lowering kit not fit the Scrambler?
Discussion Starter #2
For those who give a care, British Customs informed me the Progressive lowering kit will fit the Scrambler.
I think the scrambler has longer rear shocks than the bonney, just swap over to bonney shocks that should give you an inch straight away
1 - 3 of 3 Posts
