Finally got the Memphis Shades lowers in the mail. . . . The buffeting is almost completely gone !! . . . - still a little windy since my screen is a summer but not "knock around" turbulence
that I had before. I am not turned off by how they look either.
durdle,
Here's something for you to consider to clean up airflow with the fork mounted lowers. I had a similar dilemma when I bought my first R1200C in April of 2000. The windscreen worked pretty good but I still had quite a bit of turbulance from underneath, around the sides and over the top. I presented my problem to a buddy of mine who is a retired Ranger that flew helicopers for a very long time. Those guys really understand aerodynamics.
He first suggested I cut some "big-ole-holes" near the bottom of the screen. I immediately balked on cutting holes in a very expensive windscreen. His next suggestion was much more palatable; "lean it back several degrees", he said. Fortunately, the besign of the brackets made it very easy to accomplish that task.
Here's what happened. By leaning the windscreen back, it opened up about a 40mm gap over the headlight. That gap allows air to pass under the windscreen and eliminates the vacuum created as it passes through the air at higher speeds. The vacuum is what causes turbulance and buffeting. One would think that the gap might cause you to get a blast of air under your chin, but it does not. The air coming under the windscreen gets sucked straight up the back side of the screen by the air passing over the top of it.
I determined the lean angle by getting the screen so I could see about 2" over the top. That resulted in it being about 10* more angle than my front forks. This gave me clean air hitting me just about chin level. That is actually far better than clean air passing over the top of your helmet as it keeps your face shield cleaned off in the event you get caught in a rain storm. I found out years ago on my old R75 that a windsreen being so tall it keeps
all wind off your face also allows water to pile up on the face shield and usually on the windscreen too. Now I look over the top of the windscreen and my face shield is pretty much self cleaning from water at highway speeds.
Unfortunately, I still had a fair amount of turbulance coming off my feet, legs & knees. My next step was to add some fork mounted Parabellum lowers (similar to the ones you have). I first tried them per the drawings from Parabellum which showed them to be mounted straight across the forks and perpendicular to airflow. One lengthy test ride made it pretty clear there might be a better way. The darn things vibrated like crazy in the wind and upon checking fuel mileage at the end of that ride, I noted I had lost about 4mpg after gaining about that same amount with the new angle on the windscreen.
I next tried adjusting the angle back on the lowers so they stop an inch short of hitting the wishbone suspension. That resulted in about a 45* angle back from straight across. It cleaned up airflow past my legs so that if I hold my hand down by my knee, I start feeling wind approx. 2" out from it. The added bonus is that I got back the 4mpg plus 3 to 4 more.
All is good with clean air around the windscreen and lowers now with my 1200cc cruiser getting ~50mpg under steady throttle with good weather conditions, (no wind).
Hopefully this picture will give you a clear look at my windscreen and lowers angles.
