1 - 3 of 3 Posts
Hello,
It is a bit loose on my bike and it leaks a bit as well from there, right at the base on the case. Can I remove easily the outside plug, remove the gear and tightened something ?
Thanks.
Terry
Once you have the drive gear removed,just tighten the 7/16" AF hexagon around the bush.It will be a left-hand thread on any Triumph after '68.
1 - 3 of 3 Posts
