1 - 3 of 3 Posts
Here's a few pics taken in a hurry tonight after putting on the longer BillyBars. My inseam is 32" and I swapped out the original shorter bar for the long bar. If you're considering these I hope this helps you to decide whether you need the short or longer bar.
Easy! Two bolts and some locktite.
Normal position at front of the seat.
Right side.
Normal seat position. Notice where the seat strap is in relation to da butt.
Normal seat position with legs stretched out.
Lots of different movearounds with this setup. Good luck and I hope this helps.
Dennis
1 - 3 of 3 Posts
