I have a question? The Legend centerstands are like hens teeth, so has anyone modified another Triumph centerstand to fit the Legend? or is it way too much work. I know some people don't like them but I sure would like to put one on my legend.
Thanks,
Bob
Both stands are exactly the same except the Legend legs are about 20mm shorter, so if you can cut 20mm off the bottom of the legs and weld the feet back on they are "interchangeable".
I have a Legend stand fitted to my Adventurer.
So what other stand are you referring to? I am assuming you mean a Thunderbird stand, if that is the case then I should be able to buy an aftermarket stand and modify it.
Thanks, Bob
Yes, sorry I should have said, I ordered a Adventurer/ Thunderbird from Sprint Eng. and had to swap it for a Legend stand, and from memory it's about 15mm/ 20mm shorter than the Thunderbird all the fittings are the same.
