1 - 2 of 2 Posts
Had a set of LED indicators laying around the shed so I threw them on the Bonnie - Sweet.....
Still running the stock indicators on the rear though, so the Flasher unit is ticking away at fairly hectic rate...
Can I run a combination of LED's and standard until I replace the rears?
Does it really matter if it is flashing quick?
Will a new flasher unit for LED's fix the rapid rate of blinking or will I need to run both front and rear LED's to get it back on pace?
I won't hurt anything. If you don't mind the flash rate, don't worry about it, If you want to slow it down you can get a plug & play flasher from www.newbonneville.com. I don't think it is listed on the site, but they have it. Send them an e-mail. I think it's about $20.00. I have one on my S3 and it works fine.
1 - 2 of 2 Posts
