Some of you might recall me having a leaking fuel tank a couple of weeks ago.
I intended to get the fuel tank welded but welding chap couldn't do it for a while and I needed a quick fix as the weather looked really good for a couple of weeks. I did a little research and stumbled across a product called 'Pratley Putty' (£8 delivered) which was getting great reviews regarding patching fuel tanks. It's a south african product but it can be bought here in the uk in a couple of places. It's a two part putty which you knead together and has the consistancy of modeling clay, amazingly it's water soluble and can be smoothed with a wet finger.
I had a small crack in a weld, I cleaned the area, degreased it with some methanol, worked the putty into the crack and built a bead over it. I left it for 48hrs to fully cure ( I bought the slow curing ) and then pop a little zinc rich primer over the area. I've been riding the bike into work for 10 days now and not a sign of any fuel has appeared. It has set unbelievably hard, almost like a very hard ceramic.
I don't intend this to be a permanent fix but it appears to be doing the job until I can.
