I did a search on here, but not much luck... T140v; almost brand new Amal concentrics. Right hand carb is beginning to leak after I've pushed the tickler, but not before. I can get the leak to stop by tapping the float bowl with a screwdriver handle. The tickler itself seems to "stick" a bit at the top, just slightly. I thought I might try filing a bit off the bottom of the tickler, but wanted to post here first.
Any ideas or suggestions? Thanks, Bill
EDIT: I did a better search on here, and have a few things to look at. Thanks.
