1 - 12 of 12 Posts
Two well-established Custom Tune Maps in *.hex TuneECU format for the Tiger 955i [VIN 124106 to 206546] are now available on Tom's 1Stop Tune Shop: http://www.tomhamburg.net/Custom_Tune_list.html
10120_Adjusted_AF.hex
Tiger 955i from VIN 124106 to 206546
Tune Base 10071
Production Exhaust
Production Air Filter
With or without catalyst
Adjusted AF Tables
10121_CustomMap.hex
Tune Base 10071
TORS/Aftermarket Exhaust
Corrected/Adjusted AF & Ignition Tables
Tiger Tune
Hi Teologie,
I have been testing the 10121_CustomMap.hex tune that you made up for the last few weeks in my 2006 955 Tiger.
My bike has the TOR exhaust and a K&N air filter.
I can report back that it's really improved the rideabilty of my bike. Engine response at small throttle openings is much smoother and I have noticed that the tickover is much more stable at bang on 1200 rpm. Fuel comsumption seems around the same.
I am a happy camper, thanks very much!
Dave.
Are you sure your 2006 (MY?) Tiger 955i falls within the VIN range 124106 to 206546? Being the last year of manufacture, my 2006 Tiger 955i is from VIN # 206547. Best check to make sure...
Actually I used 10173AFMod2
Hi There,
My mistake, I actually used 10173AFMod2 from the Tom Hamburg site on my bike.
I do know that my bike runs really well on it!
Dave.
My Tiger does not run really smooth at low revs.
Mechanics are OK (valves, synchr. Etc )
App. tune 10173AFMod2 improves this behavior.
Since I am currently running with 10173, my questions are:
- what is the difference between these tunes?
- if Mod2 is better, why are the improvement not part of 10173
(10173 is released later than the Mod2)
An other question:
- I am using TuneEcu, how to compare tunes?
If I load the second tune in my laptop, squares will appear in all the boxes in the map, but that's it..
hi, I would test the 10121_CustomMap for my 2004 tiger 955i.
Any feedback? someone still using this map? any problems? thank you in advance ;)
Personally I just stick with the TOR tune. It's a well known and tested tune, and gives great results with more low down pull :).
Good luck with your choices :)
1 - 12 of 12 Posts
