Anyone using one of these???
https://www.kisantech.com/view_product.php?product=Combo-CC-1
Brief info off web page...........................
chargeGUARD Monitoring System
chargeGuard display is a digital multi-meter with 4 modes of display: a voltmeter, ammeter, ambient temperature and ICE ALERT warning.
All the features on chargeGuard are displayed graphically in both digital and analog formats. chargeGuard is designed for all motorcycles with a 12V battery. and installation is a simple plug and play operation
chargeX onboard charger
chargeX incorporates a step-charging system, meaning if the battery voltage is low more power is supplied to the battery. As the voltage increases to the fully charged condition, the amount of power supplied to the battery decreases until it is completely turned off.
This "smart" charger is built to handle all types of batteries - lead-acid, Gel-cell or AGM. Upon detection of which type, it adjusts to the higher voltage necessary for the Cell-cell and AGM batteries.
chargeX-mini Wall-mount chargers
CXM-10 has universal AC input with specific adapters for US and overseas use. A multi-color LED indicates the battery charge status.
Built-in 3-step charging cycles accomplish the battery charging quickly and maintain it safely.
CXM-20 has universal AC input with specific adapters for US and overseas use. An Electro-Luminescent (EL) bar graph display lights-up to indicate the battery charge status.
What's wrong with a Battery Tender Junior?
nothing wrong with BT. Actually use one on my Tiger. After finding further info on the Kisan product think I will pass. Primarily because of cost vs benefit. Will keep the BT and just get a 5-1 display from aerostich for the volt meter and temp gauge.
