2003 Triumph Thunderbird
During production of the Thunderbird 900s there were two types of fork tubes used, Kayaba and Showa. This resulted in two different part numbers being used: T2042920 and T2045041. The question I have is which part number goes with which type of fork tube? Anyone have the answer?
I thought it was the otherway round.
It may be. I'm easily confused...
Either way, the part numbers are correct early vs. late.
My Legend is in the early serial number block (74634), and it has Showa forks.
(The greenish lettering says "Showa", believe it or not.)
Hood Automotive tire Motor vehicle Automotive lighting Bicycle tire
Tints and shades Paint Electric blue Pattern Human leg
Differences between KYB and Showa forks.
There were two different manufacturers making the forks from 1995-2003.
I took these measurements from my Sprint and Trophys.
Here is how to tell which set your forks are:
Kayaba (KYB) Showa
VIN# 29,156 - 42,274 VIN# ? up to 29,155
VIN# 95,083 – 96,151 VIN# 42,275 – 95,082
VIN# 98,480 and higher VIN#96,152 – 98,479
Lower slider
Large access hole 21.4mm Small access hole 13.5mm
Cap screw, oil lock
Needs 10mm allen wrench Needs 6mm allen wrench
Axle clamp screws center to center
29.0 mm apart 24.5 mm apart
Cap, top of fork tube
Bigger threads O.D. 39.8mm Smaller threads O.D. 38.8mm
Dust seal
Oem part # 2040080 Oem part # 2042897
No exterior spring exterior spring
Oil seal
Oem part # 2040078 Oem # 2042894
43mm X 55mm X 9.5mm 43mm X 54mm X 11mm
Guide bushing (up by oil seal)
Oem part # 2040076 Oem part # 2042889 or Oem part # 2045862
short (11.9mm) tall (14.7mm)
Bearing tube assy. (bottom fork tube)
Oem part # 2040172 Oem part # ?
tall (19.8mm) short (14.7mm)
Hi all, thank you for your very helpful comments. Following some of my own research it seems Triumph changed from one to the other and back again, not very helpful but we have to live with it.
