1 - 20 of 24 Posts
Correct me if I am wrong? but I think the Bonneville Tap also fits,
If you get a problem with a kinked pipe you can get away with lifting the rear of the tank 1/4" or so with a stack of fender washers - did that with mine so I could locate a fuel filter under the back end of the tank - you wouldnt notice I had done it to look at the bike
Discussion Starter · #10 · (Edited)
Just as an aside, there was a lot of tank debris caught up in the extended section of the tap. mainly looked like old paint. I had to replace the fuel pipe to the carb, as the fuel hose is now much longer. I checked the fuel filter at the carb end and it was practically clear. If anyone is interested, the QD fuel connections are from the BMW r1150 adventure.
Cheers
Rob
I'm pretty sure that the vacuum take off on both of my bikes (same tap) is horizontal, not downwards like that.
Installed it today, looks the business. One question the vacuum pipe take off looks very close to the airbox, is this an issue, or just shove a pipe on and it'll work (I'm thinking kinked pipe).
Rob
there are a few different types that work - the base is the same, just where the fuel outlet go, and where the vacuum line comes in. Seems like I found one that had the fuel line towards the other side, more like how it's routed in stock form on that bike too.... you have to dig through pictures on the internet, get part numbers off of bike bandit....
Discussion Starter · #14 ·
well I'm hoping that the back half of this 250 ninja fuel tap will get me out of trouble...........$10 plus post and a few days wait to see.............I'll let you know if it works.
It might - I still think my solution is easier
did you actually try putting a vacuum line on there and running it?
Discussion Starter · #16 ·
yep, the pipe was just squashed flat............I'd have to raise the tank 3/4" to get the pipe to bend without squashing (I tried it, and it looked wrong). It is very close to the airbox..................
Rob
Rob
Ah, I see that now from your pics - hadnt noticed the gap between the tank and the frame when i looked before.
Discussion Starter · #19 ·
Well, the tap finally arrived. I stripped the necessary bits off and thankfully they all fit. The tap even came with the vacuum hose. As an aside I've now also got a few spares for the internals of the tap. Pics attached
1 - 20 of 24 Posts
