I am sure that most of you readers have heard about the K&N KN 204 oil filter issue. Well, until yesterday I had not. I went on a ride yesterday and upon parking my Bonneville SE I notice a big puddle of oil underneath the bike. I was both concerned a perplexed as I have about 2,000KM on it since the oil change. Upon further observation I noticed the oil was coming from the bottom of the filter! I of course changed the oil filter and oil and I drained the oil to see how much I had remaining which was about 2 liters. I filled the bike with the proper amount of oil and did a leak check with no further issues.
SO, I went on line to find out if anyone else had any issues with this filter. Come to find out there is a recall on this filter!!! Luckily I replaced the filter with a Fram oil filter. The probem is that K&N filter has a little 17mm nut welded to the bottom for ease of installation and removal. They evidently did not spot weld the thing correctly thus causing this failure. No more K&N filters for me. The manufacturer claims that they will replace the filter. No thanks. Just pay me for the oil I used and I am good to go. Like that will ever happen!
