1 - 13 of 13 Posts
On 2007-01-03 21:15, GrayMitchell wrote:
Ive searched the forums but cant find any jetting info with this setup...
K&N Cone Filters with Emgo Replica Dunstall pipes, AI removed??? Anyone running this?
I've fitted K&N cone filters and Predator pipes. My main jets are 138, with perfect fuel/air ratio. The needles have been raised by one shim. 71 rear wheel bhp, but thats with gas flowed and skimmed heads (10.4 - 1 compression ratio).
Had those Dunstall replicas on a 75 Norton, they're really long. They were on the quiet side for aftermarket mufflers.
Bill
On 2007-01-04 17:51, POPPE wrote:
robnobrakes,that 10:4:1 ratio wouldn't happen to be for a standard bore size would it.
Yes. The head was gas flowed, ported and skimmed. The work was carried out professionally by a local engine tuner.
On 2007-01-05 09:07, GrayMitchell wrote:
Thanks BillT100,
I had noticed that they were 27 3/4"!!! They also have a set of Emgo Dunstalls that are 18"...think those would be better?
I've seen the short ones with the BellaCorse or Newbonneville adapters and they looked good. I've heard also that they're LOUD but you can always use the 4" long J.C. Whitney baffles(part # ZX013522R) up front in the adapter pipes. I didn't check the web site but make sure the mufflers come with the adapter sleeves to fit to the adapter pipes coming off your headers and use high temp silicone for a good seal. The J.C. Whitney part # ZX017567P shorty seamless megaphone muffler is probably the same one you're talking about. Read the reviews at their web site.
Bill
[ This message was edited by: BillT100 on 2007-01-05 11:07 ]
1 - 13 of 13 Posts
