1 - 13 of 13 Posts
95 today, 97 for the next two days and then dropping down to 94 with possible scattered thunderstorms for Thursday with heat indexes from 105 to 109. And the ever present humidity. :p
If you guys who own newer bikes haven't done it already, you might want to check and flush your coolant systems and put in something other than what the factory pumped into your bikes.
Got an '07 and I did mine last fall at only a year old and like a lot of people on here I found a nice mixture of brown sludge in mine. Quite a bit of buildup in the expansion tank.
Did a few short runs after purging the system with a hose with a few fills of distilled water until it ran clean and then put in Prestone 50/50, good for all motors yada yada.
Since I started running it I've never seen more than 7 bars and that was after it had sat hot before a new start up. Today, parked for a few at the post office after 20 miles it registered 7 on start up, 4 miles later it was at 5 bars and I never saw more than six while running and it was hot today.
Not promoting Prestone but I believe anything is better than what the factory installs. I know I am running a full bar lower with this juice than what the factory put in it.
I hit 9 bars in Chi town this weekend. Just dropped it off at the dealer for a coolant and oil change, plus I melted some cable coming out of the instrument cluster!??
Going to add the engine ice as well!
As I stated in another thread, Engine Ice lowered my temp by one bar. But if you are expecting to feel a difference, forget it.
On the other hand, one bar cooler than Prestone is noteworthy, and is justification to use it.
96 degrees and 86% humidity..........some people pay money to sit in little rooms with weather like this.
---Charlie
That is an average summers day here but our humidity is usually higher than that, often the temperature is too.:veryhot:
DaveM:BigEyes:
This is pretty typical of our summer weather.......IN AUGUST!:veryhot:
Dave, don't you fry in those black leathers? I can't imagine being stuck in traffic, steamy hot, and black leathers on.
---Charlie
---Charlie
:D:D
Guess I'll stick wth the mid 70s we're having right now and low humidity....:D
Discussion Starter · #12 ·
*This is pretty typical of our summer weather.......IN AUGUST!*
Ain't that the truth! Supposed to stay this way the rest of the week with next week dipping down into the cool high 80's. Man, I get home after work and my head feels like a baked ham coming out of the oven and I wear a white helmet. :)
OND, so you are consistently running 5 bars on the engine ice? That is pretty decent.
Had a storm blow through today before work let out and the pavement got cooled and the temps were a little lower so I was running 5/6 bars on the 30 miles home. I almost sprang for a jug of the EI the last time I was at a shop. Might have to give it a try.
---Charlie
Charles,
In short I don't ride in traffic if I can ever help it.
Yes I do get very hot in black leathers in summer, Tiger Angel Leathers are also thicker than most European brands being 1.4mm - 1.6mm premium Cow and Kangaroo hide.
Having said that my average ride starts at 5:30am and is over by 11:00am especially in summer when it can be up to 40 C and 90+ humidity.
I do have a JR Phoenix Mesh jacket but wear my TA leather pants with them and use leather mesh CF gloves in the hottest part of summer.
DaveM:cool:
1 - 13 of 13 Posts
