1 - 20 of 40 Posts
I was 16 that summer when I spent my entire summer's savings on a 68 441 Victor Special ($850). I had a blast and loved that machine. I did visit the Cycle Shop to see the Nortons and Triumphs. I decided that I really needed a bright, new Bonneville! Summer ended-- I got in a couple legal scrapes sold the scooter as I turned 17 and headed into the US Army.
Now nearly 50 years later I still figured I needed a Bonneville. Well I found one right in a buds shop! After some wheeling and dealing I traded for a 1970 T120R! It shows only 16,000 miles.
My son and I farm and have a very complete shop where we will rebuild the bike.
Grandson Archer is onboard!
WOW!!!
A "survivor".
RESIST THE URGE to do a "total restoration"; instead, find a good used set of Burgess mufflers, and a decent low or mid-rise handlebar, and just give the bike a standard bike wash.
TAKE A FEW HUNDRED PHOTOS There are literally hundreds, perhaps THOUSANDS of people that would like to know which side of the coil the wires route, which path the throttle cables take, and a thousand other minute details about that bike.
Mine wasn't perfect by any stretch, but it was decent...
Great find, congratulations. And as much as I'd like to find an old classic like that, no bike will compare to the enjoyment that you'll have working on it with your son (and grandson). Looks like you have some great times in your future.
Welcome to the Forum.
Very nice find very very original bike but I'm not real impressed with the handlebars.
Is the mileage real no real way to know but on a 48 years old bike does it really matter? The bike looks to be mostly original as it has the taillight extender still on it and the horn pair. Those two things suggest the build date was after January 1, 1970 and the VIN would be after AD 37000. Also I suspect the gauges are black face. I was wondering when you look at the horns could you confirm there is a decal that says Clear Hooters and also may state HF80 That would be the correct horn for mid year '70 T120's. By the way the oval brackets on the front fender supports are incorrect
Take lots and lots of pictures before and during disassembly.
K
about the same period of time, I got a friends BSA 441 to ride. Fastest I had ever been on a motorcycle, open headers, poor fitting helmet, country roads, made it all seem faster. Made previous miles on a Honda S 90 kinda pale.....50 years later I have a Triumph Thruxton in the garage.
I agree with GPZ - if at all possible try to just clean and tidy it up - keep as much original as you can - even that will bive you enough to do - and could get you riding it quicker too
That late model 70 also had those 1971 style silencers fitted so i expect they too are original.Open rear shock springs were also standard. Very nice bike to find. Wish i could be that lucky.
Discussion Starter #9
Thanks for the great replies. Because the Bonneville is so complete I will just replace the rubber parts and tires that have desert dried plus loose the ape hangers. I appreciate the preserved "survivor" concept.
*HayMike, I spent 6 hours yesterday cutting alfalfa!
arizonamike
After looking again at your picture I note you are missing the front reflectors. Not an uncommon occurance. However in that I an also thinking about the fuel tank front mounting studs. If you should remove them be aware the short side goes into the tank. If you install the long side in the tank holes it is possible to puncture the tank.
More pictures?
K
In 1970 I was 22 and drag racing cars and chasing skirts..My first bike, a 65 BSA 650, was two years into the future...
Hi Mike,
Risking stating the obvious, the cables'll need replacing too, or at least shortening.
Uh-uh, while the mufflers/silencers in the picture of Steve McQueen are better-known as '71-on standard Triumph/BSA, the mufflers/silencers on your bike are Dunstalls, period go-faster (noisier) bits. Only thing is, if the ends have what look like the end of a Gatling gun, whether you use 'em or change 'em might depend on how loud you like your motorcycle ... :whistle
+1. Off a contemporary TR6C - the version intended for off-road riding and racing; the brackets raise the fender so the TR6C's bigger 3.50 x 19 tyre could be fitted and so mud was less-likely to clog between the tyre and the fender. Standard T120 oval brackets will move the fender closer to the tyre.
If you're going to work on the bike and look for/order new parts online, you'll need the Triumph workshop manual and parts book. You can buy paper copies through dealers but they're also free online - workshop manual, parts book.
Hth.
If you were 10 years older you would have been drag racing cars with fender skirts. :grin2: (and kerb feelers)
God Bless TV Tommy Ivo & RIP Norm Grabowski
K
Discussion Starter #17
Thanks Gents for the great comments and information. Now I need to match my budget (read wife) with time line (when can I ride) to the total restoration project! I got the bike very reasonable so there is a responsible value to work with.
Mike
Yes, what GrandPaulZ said about pictures. Never worked on motorcycles guys like me search for hours trying to figure out stuff like cable routing etc. Not much out there as far as images to use for reference. Workshop manuals don't cover every little detail. Great find, should be fun.
Discussion Starter #19
I need help! Looking for a mechanic/shop to take my 1970 Bonneville in for work. Hopefully in the south west as I am in SEAZ. I am NOT finding any time to do any restoration work.
Mike
1 - 20 of 40 Posts
