i need help guys i was riding my 1975 750 bonneville all was fine untill a loud bacKfire a pop and a Sputter and it just died
i cleaned the plugs and it started again but only ran for about 5 minute when it did it again?
i checked the wireing but cant see anything wrong i have electronic ignition on it, it starts but runs rough then splutters and runs on both cylinders then dies then kicks back to lfe then dies etc
any idea where i shouls start looking any help will be great thanks
Check that your bike is charging your battery and/or that your battery is holding a charge. Bike will do as you describe with many EI units if battery reads less than 12 Volts. Quick test, turn off headlight when bike begins to sputter. If running improves for a few more seconds, could be battery/charging issues.
what EI?
there are tests listed in the manual for RITA.
when mine packed up, it did similar random things
