Hello,
I just fitted a Norton type external oil filter. This morning it was a bit cooler here in Northern California at 50 degrees
than the 80 / 90 of the past weeks.
I started the bike and could see through the return in the tank that the oil was real " sluggish ". I went for a long ride, looked twice in the tank and it was just fine. Do you get that as well ? What happens if the weather dips in real low temps ? Will the oil circulate through the filter ?
Also, I just mounted an oil gauge. I think the numbers it shows are too high. After a 2 hours ride, at idle, it read 40 psi while the red stock oil pressure light was flickering.
Do you actually bleed or prime the oil line to the gauge at installation ?
The instructions didn't mention anything, I didn't do it. But would air trapped in the line increase the readings ?
Thanks.
Thanks.
