Just want to get my ducks in a row. I've been reading the various websites dedicated to the issue, and I've read through my Haynes manual. I have my right-angle screwdriver ready to go, and I'll have the replacement carb screw set. As far as I can tell:
.5) turn off the fuel petcock
1) Loosen the bolt to drain the gas out of the float bowl
2) Remove the four screws that hold on the float bowl cover
3) remove the main jet (while using a wrench to keep the needle jet holder from falling out)
4) install the replacement main jet
5) remove the pilot jet
6) install the replacement pilot jet
7) replace the float bowl cover
8) turn back on the fuel
9) fire her up!
The Haynes manual says I need to replace the gasket--is that really necessary? Also, which of the connectors (electrical or otherwise) must I remove before rejetting?
Thanks!
9) fire her up!
Thanks!
