http://www.flickr.com/photos/[email protected]/8072006227/in/photostream
Apologies for the vertical video. I've scoured this board several times while owning this bike and having some issues with it, but I've never seen this issue described. It will misfire and eventually drop a cylinder causing the motor to bog and die. That issue seems common. But this strange blowback is something that I haven't read anywhere else. The puff/mist actually knocks the carb back a bit and then comes out of that boot downstream of the carb.
So far I've torn down the carbs and made sure they were clean and jetted properly. Then I ordered a Procom CDI and a Nology coil. The coil is, of course, on backorder until December (I ordered it in June!). The Procom box hasn't improved the situation at all.
Since I've had time to think I'm wondering if this is even an ignition issue at all, though I don't know what else it could be. Maybe some stuck valves (it does this on both cylinders)? But the bike only has 5900 miles so that seems wrong. Would a bad ignition sensor cause this?
Anyone have any thoughts as to what could be causing this? I tried searching several times over and never found anything that seemed like an issue matching my video. Thanks for the help!
