1 - 3 of 3 Posts
The other day I discoved the hose that comes out of the crankcase had blown out. I put it back in, but it came out again.
Is there something missing in these pictures?
I plugged it back in, and secured it with JB Weld. Durring the next ride, it blew out again breaking the JB Weld.
I checked the hose and it isn't plugged. Does this mean there's something wrong with the airbox?
Also, if I switch to pod filters, what do I do with the breather hose?
Kem
well not sure on this but if the hose is blowing off all the time ,id be checking to make sure its not kinked or blocked in some way,you dont say if it has broken of were it goes into the crankcase or not,but id say with the presure in there if its broken off you need to replace hope this helps
Looks just the same as mine, so I would say from your photos that there's nothing obviously missing. It suggests to me that the hose is blocked somewhere between the crankcase and the airbox, although from what you write it reads as if the actual hose union has broken off? Could just be that under pressure the hose clip proved stronger than the metal union.
In answer to your last question, have a look at this thread, in particular the last two posts and post #21:
http://www.triumphrat.net/hinckley-classic-triples/85233-pod-mod.html
Also this thread:
http://www.triumphrat.net/hinckley-classic-triples/149539-crankcase-breather.html
and most recently, this one:
http://www.triumphrat.net/hinckley-classic-triples/156704-airfilter-pods-behind-side-panels.html
1 - 3 of 3 Posts
